Saltar al contenido principal
HP 15-ac121dx CD Compartment Replacement
Qué necesitas
  1. HP 15-ac121dx CD Compartment Replacement, Battery: paso 1, imagen 1 de 1
    • Remove all external devices from the computer.
    • Remove the charging cord from the computer.
  2. HP 15-ac121dx CD Compartment Replacement: paso 2, imagen 1 de 1
    • Turn off the computer by holding the power button.
  3. HP 15-ac121dx CD Compartment Replacement: paso 3, imagen 1 de 2 HP 15-ac121dx CD Compartment Replacement: paso 3, imagen 2 de 2
    • To remove the battery, slide the left slider on the back to the unlocked position.
  4. HP 15-ac121dx CD Compartment Replacement: paso 4, imagen 1 de 2 HP 15-ac121dx CD Compartment Replacement: paso 4, imagen 2 de 2
    • Push the right slider inwards.
    • Remove the battery out by pulling straight out and to the right.
  5. HP 15-ac121dx CD Compartment Replacement, Back Panel: paso 5, imagen 1 de 3 HP 15-ac121dx CD Compartment Replacement, Back Panel: paso 5, imagen 2 de 3 HP 15-ac121dx CD Compartment Replacement, Back Panel: paso 5, imagen 3 de 3
    • Locate the CD Compartment panel and gently slide it out.
  6. HP 15-ac121dx CD Compartment Replacement: paso 6, imagen 1 de 1
    • Remove the back of the laptop by unscrewing the screws shown.
    • Also remove the other 5 Phillips screws lining the back cover.
  7. HP 15-ac121dx CD Compartment Replacement: paso 7, imagen 1 de 3 HP 15-ac121dx CD Compartment Replacement: paso 7, imagen 2 de 3 HP 15-ac121dx CD Compartment Replacement: paso 7, imagen 3 de 3
    • Using the prying tool, wedge it underneath the back of the laptop and do the same all around until the back comes off.
    • Dont forget to unscrew 2 screws under 2 plastic tabs (one on each hing). The lid will not come off without them being removed!
  8. HP 15-ac121dx CD Compartment Replacement, CD Compartment: paso 8, imagen 1 de 3 HP 15-ac121dx CD Compartment Replacement, CD Compartment: paso 8, imagen 2 de 3 HP 15-ac121dx CD Compartment Replacement, CD Compartment: paso 8, imagen 3 de 3
    • Locate the CD Compartment as shown and gently slide it out.
Conclusión
Replace CD compartment. To reassemble your device, follow these instructions in reverse order.
4 personas más completaron esta guía.
Ashton Martin
Miembro Desde 01/30/18
459 Reputación
2 Guías creadas
Equipo
Baylor, Team S1-G2, Johnson Spring 2018 Miembro de Baylor, Team S1-G2, Johnson Spring 2018
BU-JOHNSON-S18S1G2
3 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 5
Todo El Tiempo: 410
