Saltar al contenido principal
HP 15-R263DX Disassembly
Qué necesitas
  1. HP 15-R263DX Disassembly, Battery: paso 1, imagen 1 de 2 HP 15-R263DX Disassembly, Battery: paso 1, imagen 2 de 2
    • Eject the battery from the computer by sliding the two clips on the bottom of the computer toward the center of the computer.
    • Slide the battery out as shown in the picture.
  2. HP 15-R263DX Disassembly, Optical Drive: paso 2, imagen 1 de 2 HP 15-R263DX Disassembly, Optical Drive: paso 2, imagen 2 de 2
    • Using a Phillips #1 screwdriver, remove the small screw next to the disc engraving shown in the picture.
  3. HP 15-R263DX Disassembly: paso 3, imagen 1 de 1
    • Gently slide the optical drive out of the side of the computer.
  4. HP 15-R263DX Disassembly, HP 15-R263DX Disassembly: paso 4, imagen 1 de 2 HP 15-R263DX Disassembly, HP 15-R263DX Disassembly: paso 4, imagen 2 de 2
    • Locate the two corner grips on the hinge side of the computer.
    • Using a metal spudger, remove the two corner grips to reveal the screws.
  5. HP 15-R263DX Disassembly: paso 5, imagen 1 de 1
    • Remove the 11 small screws on the bottom of the computer that are shown in the picture.
  6. HP 15-R263DX Disassembly: paso 6, imagen 1 de 1
    • Remove the 2 small screws that are on the bottom side of the disc tray slot.
    • These screws are shorter and wider than the others.
  7. HP 15-R263DX Disassembly: paso 7, imagen 1 de 2 HP 15-R263DX Disassembly: paso 7, imagen 2 de 2
    • Once the keyboard is loose, do not immediately pull away from computer. It is attached by the ribbon connector.
    • Using a spudger, pry around the edges of the keyboard until all clips are disengaged and the keyboard is loose from the computer.
    • To disconnect the ribbon connector, flip up the black clip shown in the picture.
    • Gently pull the ribbon until disconnected.
  8. HP 15-R263DX Disassembly: paso 8, imagen 1 de 2 HP 15-R263DX Disassembly: paso 8, imagen 2 de 2
    • Disconnect the other two ribbon connectors underneath the keyboard by fliping up the black clips.
    • Remove the 4 small screws shown in the picture.
  9. HP 15-R263DX Disassembly: paso 9, imagen 1 de 1
    • Disengage the face plate clips by prying the case away from around the outer edge of the face plate with a metal wedge.
    • The face plate can then be lifted away from the computer.
Conclusión
10 personas más completaron esta guía.
Dilan Johnson
Miembro Desde 02/12/18
723 Reputación
4 Guías creadas
Equipo
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 32
Todo El Tiempo: 6,567
