Introducción
A hard drive can be the source of many issues in a laptop computer. This means that it is important to know how to replace a hard drive. Before you decide to replace a hard drive, you should always attempt to back up your data to a secondary source so that nothing is lost in the process.
Qué necesitas
Flip the laptop over to reveal screw locations.
Use a metal spudger to remove the two rear rubber feet. There are screws hidden underneath them.
Remove two 5 mm Phillips #1 screws located at the base of the hard drive.
3 personas más completaron esta guía.
