Saltar al contenido principal
HP 15-BA078DX RAM Replacement
Qué necesitas
  1. HP 15-BA078DX RAM Replacement, Battery: paso 1, imagen 1 de 3 HP 15-BA078DX RAM Replacement, Battery: paso 1, imagen 2 de 3 HP 15-BA078DX RAM Replacement, Battery: paso 1, imagen 3 de 3
    • Unclip the two latches on the bottom of the laptop.
    • Slide the battery straight out while holding the clip open.
  2. HP 15-BA078DX RAM Replacement, Disc Drive: paso 2, imagen 1 de 1
    • Using the Phillips #0 screwdriver, remove the 7.5mm screw from the underside of the plastic frame that holds the disc tray in place.
  3. HP 15-BA078DX RAM Replacement: paso 3, imagen 1 de 3 HP 15-BA078DX RAM Replacement: paso 3, imagen 2 de 3 HP 15-BA078DX RAM Replacement: paso 3, imagen 3 de 3
    • Remove the disk tray assembly by sliding it out from the side using the blue plastic opening tool.
  4. HP 15-BA078DX RAM Replacement, Back Panel: paso 4, imagen 1 de 1
    • Remove all of the remaining back panel screws with a #0 Phillips head screwdriver.
    • Remember to remove the two screws under the rubber feet.
  5. HP 15-BA078DX RAM Replacement: paso 5, imagen 1 de 3 HP 15-BA078DX RAM Replacement: paso 5, imagen 2 de 3 HP 15-BA078DX RAM Replacement: paso 5, imagen 3 de 3
    • Carefully use the blue plastic opening tool to pry the clam shell of the laptop apart.
    • You may need to flip the laptop over to unlatch all of the internal clips.
  6. HP 15-BA078DX RAM Replacement: paso 6, imagen 1 de 3 HP 15-BA078DX RAM Replacement: paso 6, imagen 2 de 3 HP 15-BA078DX RAM Replacement: paso 6, imagen 3 de 3
    • Carefully pull the shell of the computer apart.
  7. HP 15-BA078DX RAM Replacement, RAM: paso 7, imagen 1 de 2 HP 15-BA078DX RAM Replacement, RAM: paso 7, imagen 2 de 2
    • Using a plastic spudger, unclip the latch locking the RAM to the motherboard.
  8. HP 15-BA078DX RAM Replacement: paso 8, imagen 1 de 3 HP 15-BA078DX RAM Replacement: paso 8, imagen 2 de 3 HP 15-BA078DX RAM Replacement: paso 8, imagen 3 de 3
    • Gently tilt the RAM sticks up and slide out each stick.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 9
Todo El Tiempo: 548
