Introducción
The guide will detail the replacement of the back panel of the HP 15-BA078DX.
  1. Unclip the two latches on the bottom of the laptop. Slide the battery straight out while holding the clip open. Slide the battery straight out while holding the clip open.
    • Unclip the two latches on the bottom of the laptop.
    • Slide the battery straight out while holding the clip open.
  2. Using the Phillips #0 screwdriver, remove the 7.5mm screw from the underside of the plastic frame that holds the disc tray in place.
    • Using the Phillips #0 screwdriver, remove the 7.5mm screw from the underside of the plastic frame that holds the disc tray in place.
  3. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  4. Remove the disk tray assembly by sliding it out from the side using the blue plastic opening tool. Remove the disk tray assembly by sliding it out from the side using the blue plastic opening tool. Remove the disk tray assembly by sliding it out from the side using the blue plastic opening tool.
    • Remove the disk tray assembly by sliding it out from the side using the blue plastic opening tool.
  5. Remove all of the remaining back panel screws with a #0 Phillips head screwdriver.
    • Remove all of the remaining back panel screws with a #0 Phillips head screwdriver.
    • Remember to remove the two screws under the rubber feet.
  6. Carefully use the blue plastic opening tool to pry the clam shell of the laptop apart. You may need to flip the laptop over to unlatch all of the internal clips. You may need to flip the laptop over to unlatch all of the internal clips.
    • Carefully use the blue plastic opening tool to pry the clam shell of the laptop apart.
    • You may need to flip the laptop over to unlatch all of the internal clips.
  7. Carefully pull the shell of the computer apart. Carefully pull the shell of the computer apart. Carefully pull the shell of the computer apart.
    • Carefully pull the shell of the computer apart.
Conclusión
Una persona más ha completado esta guía.
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 1
Últimos 30 Días: 14
Todo El Tiempo: 190
