Saltar al contenido principal
HP 15-AF131DX Trackpad Button Circuit Board Replacement
Qué necesitas
  1. HP 15-AF131DX Trackpad Button Circuit Board Replacement, Battery: paso 1, imagen 1 de 2 HP 15-AF131DX Trackpad Button Circuit Board Replacement, Battery: paso 1, imagen 2 de 2
    • Turn the computer upside down on a level surface.
    • Slide the battery lock to unlock the battery.
    • Slide the battery release latch. The latch will click when the battery is released.
    • Lift the battery from the middle to remove it from the computer.
    • The latch will click again when a battery is reinstalled. Switch the battery lock back to locked after reinstalling a battery to keep it secure.
  2. HP 15-AF131DX Trackpad Button Circuit Board Replacement, Optical Drive: paso 2, imagen 1 de 2 HP 15-AF131DX Trackpad Button Circuit Board Replacement, Optical Drive: paso 2, imagen 2 de 2
    • Using a small Phillips screwdriver, remove the Phillips screw in the middle of the bottom of the computer.
    • Pull the CD/DVD drive outward to slide it away from the computer.
  3. HP 15-AF131DX Trackpad Button Circuit Board Replacement: paso 3, imagen 1 de 1
    • To open the drive use an unbent paperclip and press it into the small hole until the disc tray releases.
    • Pull the disc tray out from the front until it is as far as it will go out of the optical drive.
  4. HP 15-AF131DX Trackpad Button Circuit Board Replacement: paso 4, imagen 1 de 3 HP 15-AF131DX Trackpad Button Circuit Board Replacement: paso 4, imagen 2 de 3 HP 15-AF131DX Trackpad Button Circuit Board Replacement: paso 4, imagen 3 de 3
    • To remove excess parts from the optical drive press down on the plastic tab behind the tray's bezel.
    • Gently pry the bezel from the face of the optical drive.
    • With a smaller phillips head screwdriver, remove the screws on the back of the drive, then remove the small metal bracket.
  5. HP 15-AF131DX Trackpad Button Circuit Board Replacement, Trackpad Button Circuit Board: paso 5, imagen 1 de 2 HP 15-AF131DX Trackpad Button Circuit Board Replacement, Trackpad Button Circuit Board: paso 5, imagen 2 de 2
    • Remove two rubber feet by peeling them off.
    • Remove twelve Phillips head 8.8mm screws using the Phillips #0 Screwdriver.
  6. HP 15-AF131DX Trackpad Button Circuit Board Replacement: paso 6, imagen 1 de 3 HP 15-AF131DX Trackpad Button Circuit Board Replacement: paso 6, imagen 2 de 3 HP 15-AF131DX Trackpad Button Circuit Board Replacement: paso 6, imagen 3 de 3
    • Remove the bottom of the plastic case using a blue plastic opening tool.
    • The Trackpad Button Circuit Board is found in the red box.
  7. HP 15-AF131DX Trackpad Button Circuit Board Replacement: paso 7, imagen 1 de 2 HP 15-AF131DX Trackpad Button Circuit Board Replacement: paso 7, imagen 2 de 2
    • Remove the two 3.3mm Phillips-head screws that secure the trackpad circuit board to the top cover.
  8. HP 15-AF131DX Trackpad Button Circuit Board Replacement: paso 8, imagen 1 de 2 HP 15-AF131DX Trackpad Button Circuit Board Replacement: paso 8, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Lift the plastic wire lock bracket.
    • Pull on the blue tab to remove the wire using the tweezers tool to make sure there is no damage as you pull.
  9. HP 15-AF131DX Trackpad Button Circuit Board Replacement: paso 9, imagen 1 de 2 HP 15-AF131DX Trackpad Button Circuit Board Replacement: paso 9, imagen 2 de 2
    • Lift the second plastic wire lock bracket.
    • Pull on the purple tab using tweezers to remove the wire.
  10. HP 15-AF131DX Trackpad Button Circuit Board Replacement: paso 10, imagen 1 de 1
    • Lift and remove the trackpad button circuit board.
Conclusión
Adrianna
Miembro Desde 11/01/18
133 Reputación
1 Guía escrita
Equipo
IUPUI, Team S2-G2, Harley Fall 2018 Miembro de IUPUI, Team S2-G2, Harley Fall 2018
IUPUI-HARLEY-F18S2G2
3 Miembros
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 358
