Saltar al contenido principal
HP 15-AF131DX Speaker Replacement
Qué necesitas
  1. HP 15-AF131DX Speaker Replacement, Speakers: paso 1, imagen 1 de 2 HP 15-AF131DX Speaker Replacement, Speakers: paso 1, imagen 2 de 2
    • Use a Phillips screwdriver to remove the 10 visible screws on the bottom.
    • Peel up the rubber feet near the hinges.
    • Remove the screw under each.
  2. HP 15-AF131DX Speaker Replacement: paso 2, imagen 1 de 2 HP 15-AF131DX Speaker Replacement: paso 2, imagen 2 de 2
    Herramienta utilizada en este paso:
    Plastic Cards
    $2.99
    • Turn the computer over and use a plastic card, opening pick, or opening tool to pry the space between the keyboard and bottom surface of the computer.
    • Work plastic card, opening pick, or opening tool carefully around the three edges (excluding the side with the screen, which should be positioned at 90 degrees.
    • Gently lift the top surface of the bottom half of the laptop, revealing the speakers.
  3. HP 15-AF131DX Speaker Replacement: paso 3, imagen 1 de 3 HP 15-AF131DX Speaker Replacement: paso 3, imagen 2 de 3 HP 15-AF131DX Speaker Replacement: paso 3, imagen 3 de 3
    • Pull up on each individual speaker, removing the rubber holds from their plastic pins.
    • Unplug the wire that connects the speakers.
    • Carefully remove the speakers from their plastic holds.
Conclusión
Equipo
Cal Poly, Team S6-G2, Banghart Fall 2017 Miembro de Cal Poly, Team S6-G2, Banghart Fall 2017
CPSU-BANGHART-F17S6G2
Miembros de 5
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 656
