Saltar al contenido principal
HP 15-AF131DX Optical Drive Replacement
Qué necesitas
  1. HP 15-AF131DX Optical Drive Replacement, Optical Drive: paso 1, imagen 1 de 2 HP 15-AF131DX Optical Drive Replacement, Optical Drive: paso 1, imagen 2 de 2
    • Using a small Phillips screwdriver, remove the Phillips screw in the middle of the bottom of the computer.
    • Pull the CD/DVD drive outward to slide it away from the computer.
  2. HP 15-AF131DX Optical Drive Replacement: paso 2, imagen 1 de 1
    • To open the drive use an unbent paperclip and press it into the small hole until the disc tray releases.
    • Pull the disc tray out from the front until it is as far as it will go out of the optical drive.
  3. HP 15-AF131DX Optical Drive Replacement: paso 3, imagen 1 de 3 HP 15-AF131DX Optical Drive Replacement: paso 3, imagen 2 de 3 HP 15-AF131DX Optical Drive Replacement: paso 3, imagen 3 de 3
    • To remove excess parts from the optical drive press down on the plastic tab behind the tray's bezel.
    • Gently pry the bezel from the face of the optical drive.
    • With a smaller phillips head screwdriver, remove the screws on the back of the drive, then remove the small metal bracket.
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team S6-G2, Banghart Fall 2017 Miembro de Cal Poly, Team S6-G2, Banghart Fall 2017
CPSU-BANGHART-F17S6G2
5 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 7
Todo El Tiempo: 472
