Saltar al contenido principal
HP 14-fq1025nr Screen Replacement
Qué necesitas
  1. HP 14-fq1025nr Screen Replacement, Back Cover: paso 1, imagen 1 de 1
    • Flip the laptop upside down so the bottom cover is facing up.
  2. HP 14-fq1025nr Screen Replacement: paso 2, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Use a pair of tweezers to grab and pull the feet off of the cover.
  3. HP 14-fq1025nr Screen Replacement: paso 3, imagen 1 de 1
    • Remove the two 4 mm screws using a Phillips #0 screwdriver.
    • Remove the six remaining 6 mm screws located around the edges and underneath the feet using a Phillips #0 screwdriver.
  4. HP 14-fq1025nr Screen Replacement: paso 4, imagen 1 de 1
    • Flip the laptop right-side up and slide an iFixit opening tool and/or Jimmy inside of the bottom cover seam to pry it open.
  5. HP 14-fq1025nr Screen Replacement: paso 5, imagen 1 de 1
    • Remove the bottom cover.
  6. HP 14-fq1025nr Screen Replacement, Screen: paso 6, imagen 1 de 3 HP 14-fq1025nr Screen Replacement, Screen: paso 6, imagen 2 de 3 HP 14-fq1025nr Screen Replacement, Screen: paso 6, imagen 3 de 3
    • Remove the four black 5 mm screws holding down the two silver screen hinges using a Phillips #00 screwdriver.
  7. HP 14-fq1025nr Screen Replacement: paso 7, imagen 1 de 2 HP 14-fq1025nr Screen Replacement: paso 7, imagen 2 de 2
    • Unplug the screen from the motherboard by lifting the wire cover and removing the screen cord.
    • Separate the hinges from the computer.
  8. HP 14-fq1025nr Screen Replacement: paso 8, imagen 1 de 1
    • Remove the screen.
Conclusión
Yasli Kanimba Murenzi
Miembro Desde 09/27/22
193 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 24
Todo El Tiempo: 284
