Saltar al contenido principal
HP 14-fq1025nr Motherboard Replacement
Qué necesitas
  1. HP 14-fq1025nr Motherboard Replacement, Back Cover: paso 1, imagen 1 de 1
    • Flip the laptop upside down so the bottom cover is facing up.
  2. HP 14-fq1025nr Motherboard Replacement: paso 2, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Use a pair of tweezers to grab and pull the feet off of the cover.
  3. HP 14-fq1025nr Motherboard Replacement: paso 3, imagen 1 de 1
    • Remove the two 4 mm screws using a Phillips #0 screwdriver.
    • Remove the six remaining 6 mm screws located around the edges and underneath the feet using a Phillips #0 screwdriver.
  4. HP 14-fq1025nr Motherboard Replacement: paso 4, imagen 1 de 1
    • Flip the laptop right-side up and slide an iFixit opening tool and/or Jimmy inside of the bottom cover seam to pry it open.
  5. HP 14-fq1025nr Motherboard Replacement: paso 5, imagen 1 de 1
    • Remove the bottom cover.
  6. HP 14-fq1025nr Motherboard Replacement, Battery: paso 6, imagen 1 de 2 HP 14-fq1025nr Motherboard Replacement, Battery: paso 6, imagen 2 de 2
    • Remove the four gray 3 mm screws holding down the battery using a Phillips #0 screwdriver.
  7. HP 14-fq1025nr Motherboard Replacement: paso 7, imagen 1 de 1
    • Remove the battery.
  8. HP 14-fq1025nr Motherboard Replacement, Fan: paso 8, imagen 1 de 1
    • Remove the three silver screws (one 2 mm screw and two 4 mm screws) holding down the fan using a Phillips #0 screwdriver.
  9. HP 14-fq1025nr Motherboard Replacement: paso 9, imagen 1 de 1
    Comprar
    • Unplug the fan’s power cord from the motherboard.
    • Use tweezers to pull the plug out, if needed.
  10. HP 14-fq1025nr Motherboard Replacement: paso 10, imagen 1 de 1
    • Remove the fan.
  11. HP 14-fq1025nr Motherboard Replacement, Heat Sink: paso 11, imagen 1 de 1
    • Remove the four gray 3 mm screws around the heat sink using a Phillips #0 screwdriver.
    • Remove the heat sink.
  12. HP 14-fq1025nr Motherboard Replacement, SSD: paso 12, imagen 1 de 1
    • Remove the single 6 mm screw holding down the SSD using a Phillips #0 screwdriver.
  13. HP 14-fq1025nr Motherboard Replacement: paso 13, imagen 1 de 1
    • Slide the SSD out of the slot.
  14. HP 14-fq1025nr Motherboard Replacement, Motherboard: paso 14, imagen 1 de 3 HP 14-fq1025nr Motherboard Replacement, Motherboard: paso 14, imagen 2 de 3 HP 14-fq1025nr Motherboard Replacement, Motherboard: paso 14, imagen 3 de 3
    • Remove the five 3 mm gray screws from around the motherboard using a Phillips #00 screwdriver.
  15. HP 14-fq1025nr Motherboard Replacement: paso 15, imagen 1 de 2 HP 14-fq1025nr Motherboard Replacement: paso 15, imagen 2 de 2
    Comprar
    • Unplug the wire connections.
    • Use tweezers if needed.
  16. HP 14-fq1025nr Motherboard Replacement: paso 16, imagen 1 de 1
    • Remove the motherboard.
    • Use the iFixit opening tool to pry it out if needed.
Conclusión
Alex Cutler
Miembro Desde 09/26/22
301 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 18
Todo El Tiempo: 318
