Saltar al contenido principal
HP 14-fq1025nr Fan Replacement
Qué necesitas
  1. HP 14-fq1025nr Fan Replacement, Back Cover: paso 1, imagen 1 de 1
    • Flip the laptop upside down so the bottom cover is facing up.
  2. HP 14-fq1025nr Fan Replacement: paso 2, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Use a pair of tweezers to grab and pull the feet off of the cover.
  3. HP 14-fq1025nr Fan Replacement: paso 3, imagen 1 de 1
    • Remove the two 4 mm screws using a Phillips #0 screwdriver.
    • Remove the six remaining 6 mm screws located around the edges and underneath the feet using a Phillips #0 screwdriver.
  4. HP 14-fq1025nr Fan Replacement: paso 4, imagen 1 de 1
    • Flip the laptop right-side up and slide an iFixit opening tool and/or Jimmy inside of the bottom cover seam to pry it open.
  5. HP 14-fq1025nr Fan Replacement: paso 5, imagen 1 de 1
    • Remove the bottom cover.
  6. HP 14-fq1025nr Fan Replacement, Fan: paso 6, imagen 1 de 1
    • Remove the three silver screws (one 2 mm screw and two 4 mm screws) holding down the fan using a Phillips #0 screwdriver.
  7. HP 14-fq1025nr Fan Replacement: paso 7, imagen 1 de 1
    Comprar
    • Unplug the fan’s power cord from the motherboard.
    • Use tweezers to pull the plug out, if needed.
  8. HP 14-fq1025nr Fan Replacement: paso 8, imagen 1 de 1
    • Remove the fan.
Conclusión
Alex Cutler
Miembro Desde 09/26/22
301 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 119
