Introducción
This guide will teach you how to remove the battery of a HP 14-fq1025nr laptop and replace it a new one.
The battery provides and stores power for the computer. If faulty, the device may fail to boot up or lose power quickly. Prior to removing the battery, check for any leaks or damages to the component. For additional information and help with troubleshooting the battery, refer to our troubleshooting page.
Before proceeding with this guide, make sure the laptop has been completely turned off and unplugged from any power cords.
WARNING: The computer uses a lithium-ion battery which contains toxic substances / flammable substances. Handle with caution.
Qué necesitas
Remove the four gray 3 mm screws holding down the battery using a Phillips #0 screwdriver.
