Saltar al contenido principal
HP 14-fq1025nr Battery Replacement
Qué necesitas
  1. HP 14-fq1025nr Battery Replacement, Back Cover: paso 1, imagen 1 de 1
    • Flip the laptop upside down so the bottom cover is facing up.
  2. HP 14-fq1025nr Battery Replacement: paso 2, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Use a pair of tweezers to grab and pull the feet off of the cover.
  3. HP 14-fq1025nr Battery Replacement: paso 3, imagen 1 de 1
    • Remove the two 4 mm screws using a Phillips #0 screwdriver.
    • Remove the six remaining 6 mm screws located around the edges and underneath the feet using a Phillips #0 screwdriver.
  4. HP 14-fq1025nr Battery Replacement: paso 4, imagen 1 de 1
    • Flip the laptop right-side up and slide an iFixit opening tool and/or Jimmy inside of the bottom cover seam to pry it open.
  5. HP 14-fq1025nr Battery Replacement: paso 5, imagen 1 de 1
    • Remove the bottom cover.
  6. HP 14-fq1025nr Battery Replacement, Battery: paso 6, imagen 1 de 2 HP 14-fq1025nr Battery Replacement, Battery: paso 6, imagen 2 de 2
    • Remove the four gray 3 mm screws holding down the battery using a Phillips #0 screwdriver.
  7. HP 14-fq1025nr Battery Replacement: paso 7, imagen 1 de 1
    • Remove the battery.
Conclusión
Nil Parra
Miembro Desde 09/27/22
485 Reputación
4 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 19
Todo El Tiempo: 369
