Introducción
If your HP 14-dq0060nr is in need of a RAM upgrade or is just in need of a replacement, use this guide to replace the RAM itself.
The RAM is a volatile memory bank that makes it easier for your device to access information. It helps you load applications, surf the internet, edit documents, etc.
Before beginning, make sure to power off your device completely and disconnect from any external power source.
Qué necesitas
Flip the laptop over so the backside is facing up.
Use a spudger to remove the grips from the back case to reveal screws underneath.
