Introducción
If your HP 14-dq0060nr is not turning on due to a battery issue or lost its ability to charge, use this guide to replace the battery itself.
A working battery provides power to your device. Eventually, the device battery will drain after going through numerous charge cycles. If you notice that your charged battery is draining more quickly than usual, consider calibrating your battery to determine an accurate charging capacity. If you continue to notice significant drops in battery percentage, you should replace your battery.
Reference the battery troubleshooting guide to see if you can fix the issue another way first. Battery Troubleshooting Guide
Before beginning, make sure to power off your phone completely and disconnect from any external power source.
Qué necesitas
Flip the laptop over so the backside is facing up.
Use a spudger to remove the grips from the back case to reveal screws underneath.
