Saltar al contenido principal
Introducción
This guide will aid in replacing the keys of the keyboard.
Partes
No se especificaron partes.
  1. Use your prying tool to get under the key and gently pull it upwards to disengage the clips. Make sure the black scissor switch mechanism stays in place, as it is needed when putting the key back in (in second picture: the black piece surrounding the white plastic dome)
    • Use your prying tool to get under the key and gently pull it upwards to disengage the clips.
    • Make sure the black scissor switch mechanism stays in place, as it is needed when putting the key back in (in second picture: the black piece surrounding the white plastic dome)
  2. Kits de Reparación de Batería de iPhone
    Sólo $29.99
    Buy Now
    Sólo $29.99
    Buy Now
Conclusión
Brian Hall
Miembro Desde 23/10/18
85 Reputación
1 Guía escrita
Equipo
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 4
Todo El Tiempo: 49
