Saltar al contenido principal
Introducción
If your computer isn't making any sound, makes distorted sound, or otherwise has sound issues and you have ruled out software issues, you can try replacing your internal speakers using these steps.
Partes
No se especificaron partes.
  1. Remove battery by pushing the two buttons inward.
    • Remove battery by pushing the two buttons inward.
  2. Remove the two rubber feet next to the battery.
    • Remove the two rubber feet next to the battery.
  3. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  4. Remove all 14 Phillips head #0  screws.
    • Remove all 14 Phillips head #0 screws.
  5. Use a plastic opener tool to pry off the black backplate.
    • Use a plastic opener tool to pry off the black backplate.
  6. Disconnect the speakers from motherboard. Remove the speakers by lifting them straight upward. Remove the speakers by lifting them straight upward.
    • Disconnect the speakers from motherboard.
    • Remove the speakers by lifting them straight upward.
Conclusión
Antonio Leonti
Miembro Desde 26/10/18
383 Reputación
3 Guías creadas
Equipo
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 86
