Saltar al contenido principal
HMDX Jam Plus Battery Replacement
Qué necesitas
  1. HMDX Jam Plus Battery Replacement, Battery: paso 1, imagen 1 de 3 HMDX Jam Plus Battery Replacement, Battery: paso 1, imagen 2 de 3 HMDX Jam Plus Battery Replacement, Battery: paso 1, imagen 3 de 3
    • Flip the device over so the bottom is facing up.
    • Use the large plastic opening tool to gently pry the rubber base from the device.
    • Slowly move the plastic opening tool around the edge of the rubber base to separate it from the plastic.
  2. HMDX Jam Plus Battery Replacement: paso 2, imagen 1 de 2 HMDX Jam Plus Battery Replacement: paso 2, imagen 2 de 2
    • Use a Phillips #1 screwdriver to remove the four black 9mm screws from the device.
  3. HMDX Jam Plus Battery Replacement: paso 3, imagen 1 de 2 HMDX Jam Plus Battery Replacement: paso 3, imagen 2 de 2
    • Gently separate the base from the rest of the device to reveal the battery and the main board.
  4. HMDX Jam Plus Battery Replacement: paso 4, imagen 1 de 3 HMDX Jam Plus Battery Replacement: paso 4, imagen 2 de 3 HMDX Jam Plus Battery Replacement: paso 4, imagen 3 de 3
    • Carefully use the plastic opening tool to remove the glue around the battery and speaker connectors.
    • Pull gently on the connectors to separate each one from the main board.
    • The battery is connected to board in the red socket and the speaker is connected in the white socket.
  5. HMDX Jam Plus Battery Replacement: paso 5, imagen 1 de 3 HMDX Jam Plus Battery Replacement: paso 5, imagen 2 de 3 HMDX Jam Plus Battery Replacement: paso 5, imagen 3 de 3
    • Batteries can be very dangerous if punctured. Use extra caution when using tools around the battery.
    • Use the plastic opening tool to gently pry the battery free from the rest of the device.
  6. HMDX Jam Plus Battery Replacement: paso 6, imagen 1 de 2 HMDX Jam Plus Battery Replacement: paso 6, imagen 2 de 2
    • Use new adhesive to secure battery back to the rest of the device.
Conclusión
4 personas más completaron esta guía.
Maxwell Erickson
Miembro Desde 10/22/15
587 Reputación
4 Guías creadas
Equipo
Montana Tech, Team 10-3, Shirk Fall 2015 Miembro de Montana Tech, Team 10-3, Shirk Fall 2015
MTUM-SHIRK-F15S10G3
4 Miembros
4 Guías creadas
6 comentarios
Where may battery be purchased?
Thanks,
zappenfusen
warnsdorff - Contestar
Where to purchase battery for hmdx jam speaker
Frank David -
Where can a battery be purchased?
robertwacker - Contestar
What kind (especifications) that battery?
vecchio.farias - Contestar
Where to buy battery for HMDX JAM.Bluetooth speaker
Frank David - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 37
Todo El Tiempo: 7,173
