Introducción
This guide provides steps for replacing a damaged Micro USB Jack on the HMDX Jam Plus. This guide requires previous soldering skill and utilizes a Micro Soldering Iron. This guide is should not be attempted by beginners. If performed incorrectly the device may not function anymore.
Qué necesitas
Flip the device over so the bottom is facing up.
Use the large plastic opening tool to gently pry the rubber base from the device.
Slowly move the plastic opening tool around the edge of the rubber base to separate it from the plastic.
Remove the three black 6mm screws from the main board using a Philips #00 screwdriver.
Use the Micro soldering iron to heat up each pad and use the desoldering wick to wick up the melted solder.
The surface mount jack should pull from the surface without much force. Use tweezers to apply upward pressure on on the jack.
