Saltar al contenido principal
HMDX Chill Front Buttons Replacement
Qué necesitas
  1. HMDX Chill Front Buttons Replacement, Remove Rubber Base: paso 1, imagen 1 de 3 HMDX Chill Front Buttons Replacement, Remove Rubber Base: paso 1, imagen 2 de 3 HMDX Chill Front Buttons Replacement, Remove Rubber Base: paso 1, imagen 3 de 3
    • Insert a metal spudger under the rubber base.
    • Pry the rubber base off.
  2. HMDX Chill Front Buttons Replacement: paso 2, imagen 1 de 1
    • Use a Phillips #1 screwdriver to remove four 9 mm screws from the base of the device.
  3. HMDX Chill Front Buttons Replacement: paso 3, imagen 1 de 2 HMDX Chill Front Buttons Replacement: paso 3, imagen 2 de 2
    • Grip the base of the HMDX Chill.
    • Pull the base upwards.
  4. HMDX Chill Front Buttons Replacement, Front Buttons: paso 4, imagen 1 de 1
    • Using a metal spudger, push the small latch upwards towards the button from the bottom of the base.
    • These are located underneath the rubber base, prior to removal.
  5. HMDX Chill Front Buttons Replacement: paso 5, imagen 1 de 2 HMDX Chill Front Buttons Replacement: paso 5, imagen 2 de 2
    • Insert a spudger into the slit between the bottom of the buttons and the speaker base.
    • Push the buttons upwards, away from the base, until they come loose.
    • Use your hand to pull the linked buttons off the base.
Conclusión
Equipo
EWU-Giguere-S16S1G1 Miembro de EWU-Giguere-S16S1G1
Community
4 Miembros
7 Guías creadas
Un comentario
where can I buy new front buttons for replacement?
syanco_jim - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 5
Todo El Tiempo: 452
