Introducción
If your HMDX Chill will not play through headphones or other audio port devices, you can fix the problem by replacing the audio port. This guide will show you how to disassemble the HMDX Chill. This guide will also show you how to locate the audio port so you can replace the defective audio port.
Qué necesitas
Insert a metal spudger under the rubber base.
Pry the rubber base off.
Use a Phillips #1 screwdriver to remove the four 6 mm screws that secure the motherboard to the base of the device.
