Saltar al contenido principal
HMDX Chill Audio Port Replacement
Qué necesitas
  1. HMDX Chill Audio Port Replacement, Remove Rubber Base: paso 1, imagen 1 de 3 HMDX Chill Audio Port Replacement, Remove Rubber Base: paso 1, imagen 2 de 3 HMDX Chill Audio Port Replacement, Remove Rubber Base: paso 1, imagen 3 de 3
    • Insert a metal spudger under the rubber base.
    • Pry the rubber base off.
  2. HMDX Chill Audio Port Replacement: paso 2, imagen 1 de 1
    • Use a Phillips #1 screwdriver to remove four 9 mm screws from the base of the device.
  3. HMDX Chill Audio Port Replacement: paso 3, imagen 1 de 2 HMDX Chill Audio Port Replacement: paso 3, imagen 2 de 2
    • Grip the base of the HMDX Chill.
    • Pull the base upwards.
  4. HMDX Chill Audio Port Replacement, Motherboard: paso 4, imagen 1 de 3 HMDX Chill Audio Port Replacement, Motherboard: paso 4, imagen 2 de 3 HMDX Chill Audio Port Replacement, Motherboard: paso 4, imagen 3 de 3
    • Use a Phillips #1 screwdriver to remove the four 6 mm screws that secure the motherboard to the base of the device.
  5. HMDX Chill Audio Port Replacement: paso 5, imagen 1 de 1
    • Pull the motherboard away from the base gently.
    • Do not pull too hard on the motherboard. It is still attached to the base by wires.
  6. HMDX Chill Audio Port Replacement: paso 6, imagen 1 de 3 HMDX Chill Audio Port Replacement: paso 6, imagen 2 de 3 HMDX Chill Audio Port Replacement: paso 6, imagen 3 de 3
    • Use a soldering iron to desolder the wires connecting the motherboard to the case.
  7. HMDX Chill Audio Port Replacement: paso 7, imagen 1 de 2 HMDX Chill Audio Port Replacement: paso 7, imagen 2 de 2
    • Insert the spudger between the case and the wire and move the spudger upwards.
    • This will cause the case to prop open.
    • The wire behind the motherboard will now be visible. Pull this out from behind.
  8. HMDX Chill Audio Port Replacement: paso 8, imagen 1 de 1
    • Use the soldering iron to desolder the wires connecting the motherboard to the base of the HMDX Chill.
  9. HMDX Chill Audio Port Replacement, Audio Jack: paso 9, imagen 1 de 1
    • Desolder the audio jack from the motherboard using a soldering iron.
Conclusión
Equipo
EWU-Giguere-S16S1G1 Miembro de EWU-Giguere-S16S1G1
Community
4 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 401
