Introducción
During this guide you will be required to unsolder an LED from a PCB and then solder the new LED onto the same connection points.
Qué necesitas
Insert the flat tip of the metal spudger into the seam between the back panel and the screen.
Slide the spudger across the perimeter of the device and gently pry apart at each corner.
After the pressure clamps are released orient the device so that the speaker is to the right and the screen is tilted away from you.
Gently grasp the foam ring with pliers and pull upwards to release the adhesive on the bottom of the ring.
Using a soldering iron apply heat to the connection point where the LED connects to the PCB.
When the solder is heated sufficiently (turns liquid and shiny) insert the LED lead with tweezers. If necessary add additional solder to ensure a solid electrical connection.
Repeat for the other connection point.
