Qué necesitas
Insert the plastic opening tool between the digitizer and the case.
Place the spudger in the gap created by the plastic opening tool to assist in separation.
Herramienta utilizada en este paso:Desoldering Pump$3.99
Suck up the leftover solder using the desoldering pump.
Remove the wifi antenna from the motherboard.
Casi Terminas!
Conclusión
