Saltar al contenido principal
HKC P776A Battery Replacement
Qué necesitas
  1. HKC P776A Battery Replacement, Separating Digitizer and Case: paso 1, imagen 1 de 1
    • Insert the plastic opening tool between the digitizer and the case.
    • Place the spudger in the gap created by the plastic opening tool to assist in separation.
  2. HKC P776A Battery Replacement: paso 2, imagen 1 de 2 HKC P776A Battery Replacement: paso 2, imagen 2 de 2
    • Slide the spudger along the perimeter of the device to fully separate the two pieces.
  3. HKC P776A Battery Replacement, Battery: paso 3, imagen 1 de 1
    • Insert the plastic opening tool between the battery and case.
    • Apply leverage to break the glue that is attaching the battery to the case.
  4. HKC P776A Battery Replacement: paso 4, imagen 1 de 1
    • Continue breaking the glue along the perimeter of the battery until the battery can be removed.
    • Breaking all the glue between the battery and case may take a long time.
  5. HKC P776A Battery Replacement: paso 5, imagen 1 de 2 HKC P776A Battery Replacement: paso 5, imagen 2 de 2
    • Using the soldering iron, heat up the solder that is attaching the battery to the motheboard.
    • The heat from the soldering iron may cause personal injury or damage the internal components of the tablet.
  6. HKC P776A Battery Replacement: paso 6, imagen 1 de 1
    • Suck up the leftover solder using the desoldering pump.
    • Remove the battery from the motherboard.
Conclusión
Ryan Gornati
Miembro Desde 01/22/15
409 Reputación
4 Guías creadas
Equipo
USF Tampa, Team 7-6, Remmell Winter 2015 Miembro de USF Tampa, Team 7-6, Remmell Winter 2015
USFT-REMMELL-W15S7G6
3 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 8
Todo El Tiempo: 640
