Saltar al contenido principal
HKC P771A Digitizer Replacement
Qué necesitas
  1. HKC P771A Digitizer Replacement, Digitizer: paso 1, imagen 1 de 2 HKC P771A Digitizer Replacement, Digitizer: paso 1, imagen 2 de 2
    • Remove back of tablet using the plastic opening tool
    • Slide the opening tool between the back of the tablet and the digitizer
    • Lift along the edges until the back of the tablet and the digitizer are separated
  2. HKC P771A Digitizer Replacement: paso 2, imagen 1 de 2 HKC P771A Digitizer Replacement: paso 2, imagen 2 de 2
    • Remove 4 screws located on the red motherboard
    • The red motherboard will be loose, but does not need to come completely unattached
  3. HKC P771A Digitizer Replacement: paso 3, imagen 1 de 1
    • Remove 7 screws located around the edges of the tablet
    • 5 screws are visible around the edges of the device and 2 screws are located underneath the red motherboard
  4. HKC P771A Digitizer Replacement: paso 4, imagen 1 de 1
    • Lift digitizer from the screen
    • After removing all of the screws, the screen should easily separate from the digitizer
  5. HKC P771A Digitizer Replacement: paso 5, imagen 1 de 1
    • Now you can replace the old digitizer with a new one
Conclusión
Sara Hill
Miembro Desde 09/30/15
101 Reputación
2 Guías creadas
Equipo
Ohio State, Team 2-3, Garvin Fall 2015 Miembro de Ohio State, Team 2-3, Garvin Fall 2015
OSU-GARVIN-F15S2G3
4 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 254
