Saltar al contenido principal
HAMILTON C-1 Preventative Maintenance for Air, Fan, and HEPA Filters Replacement
Equipo médico
El fabricante de este equipo médico no ha avalado o contratado a iFixit ni a esta guía de reparación.
Qué necesitas
  1. HAMILTON C-1 Preventative Maintenance for Air, Fan, and HEPA Filters Replacement, Air Filter: paso 1, imagen 1 de 2 HAMILTON C-1 Preventative Maintenance for Air, Fan, and HEPA Filters Replacement, Air Filter: paso 1, imagen 2 de 2
    • Turn the Hamilton-C1 so that the rear view of the device is facing you.
    • Use your fingers to grasp the current air filter located at number 4 of the graphic and pull the filter out of the slot.
  2. HAMILTON C-1 Preventative Maintenance for Air, Fan, and HEPA Filters Replacement: paso 2, imagen 1 de 1
    • Insert a new air filter into the slot located at number 4.
  3. HAMILTON C-1 Preventative Maintenance for Air, Fan, and HEPA Filters Replacement, Fan Filter: paso 3, imagen 1 de 2 HAMILTON C-1 Preventative Maintenance for Air, Fan, and HEPA Filters Replacement, Fan Filter: paso 3, imagen 2 de 2
    • Orient the Hamilton-C1 to the right side so that the gas connections are visible.
    • Grab and remove the fan filter located at location number 5 in the graphic.
  4. HAMILTON C-1 Preventative Maintenance for Air, Fan, and HEPA Filters Replacement: paso 4, imagen 1 de 1
    • Place a new fan filter into the designated slot.
  5. HAMILTON C-1 Preventative Maintenance for Air, Fan, and HEPA Filters Replacement, HEPA Filter: paso 5, imagen 1 de 2 HAMILTON C-1 Preventative Maintenance for Air, Fan, and HEPA Filters Replacement, HEPA Filter: paso 5, imagen 2 de 2
    • Orient the Hamilton-C1 so the back is facing you.
    • Remove the back panel as labeled by number 6 of the graphic using a Phillips #1 screwdriver.
  6. HAMILTON C-1 Preventative Maintenance for Air, Fan, and HEPA Filters Replacement: paso 6, imagen 1 de 1
    • Remove the current HEPA filter by pulling the filter outward and down.
    • Insert the new HEPA filter into the slot.
Conclusión
Tina Vo
Miembro Desde 04/06/20
538 Reputación
4 Guías creadas
Equipo
Cal Poly, Team S7-G11, Paton Spring 2020 Miembro de Cal Poly, Team S7-G11, Paton Spring 2020
CPSU-PATON-S20S7G11
2 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 333
