Saltar al contenido principal
HAMILTON C-1 Bacterial Filter Replacement (Coaxial Circuit Setup)
Equipo médico
El fabricante de este equipo médico no ha avalado o contratado a iFixit ni a esta guía de reparación.
  1. HAMILTON C-1 Bacterial Filter Replacement (Coaxial Circuit Setup), Bacterial Filter: paso 1, imagen 1 de 1
    • Orient Hamilton-C1 so the right side of the device is facing you.
  2. HAMILTON C-1 Bacterial Filter Replacement (Coaxial Circuit Setup): paso 2, imagen 1 de 1
    • Disconnect HME (heat and moisture exchanger) and flex tube
    • Bacterial filter is held within the HME.
    • Use both hands to gently pull and/or twist the flex tube and HME away from one another until fully disconnected.
    • The HME should still be connected to the overall circuit setup.
    • In reassembly, a new HME with a non-contaminated bacterial filter will be reconnected to the flex tube for this step.
  3. HAMILTON C-1 Bacterial Filter Replacement (Coaxial Circuit Setup): paso 3, imagen 1 de 1
    • Disconnect HME and circuit setup
    • Use both hands to gently pull and/or twist the flow sensor and HME away from one another until fully disconnected.
    • The HME (with used/contaminated bacterial filter) should now be completely disconnected from all parts.
    • In reassembly, a new HME with a non-contaminated bacterial filter will be reconnected to the flow sensor for this step.
Conclusión
Luisa Chiu
Miembro Desde 04/06/20
205 Reputación
2 Guías creadas
Equipo
Cal Poly, Team S7-G11, Paton Spring 2020 Miembro de Cal Poly, Team S7-G11, Paton Spring 2020
CPSU-PATON-S20S7G11
2 Miembros
6 Guías creadas
Un comentario
Okay how offen should change out a carbon filter?
Bill Mcleod - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 5
Ultimos 30 días: 13
Todo El Tiempo: 700
