This guide will help teach the readers how to replace a standard guitar nut. To tell what type of guitar nut is on your guitar follow this link to determine if this guide is suitable for your guitar. The guitar nut is a necessity to be fixed on a guitar to keep the strings in place. This guide assumes that the reader has basic knowledge of guitars and their parts.
Turn the knobs to unwind all guitar strings currently on the guitar.
For this type of guitar turn the knobs on the right side clockwise and the left side counter-clockwise. Double-check this process by pulling the strings gently to see if the strings are losing tension.
Sand away excess old glue in the groove of the guitar head.
Using the 80 grit sandpaper first is recommended, as this helps to remove tougher glue. Using the 120 grit sandpaper helps to smooth out the groove and eases laster steps.
Now that your guitar is repaired don’t forget to tune the guitar. The website https://guitar-tuner.org/ is an excellent resource for tuning your instrument.
Conclusión
