Saltar al contenido principal
Introducción
This guide will teach the user how to install the right side panel and align the buttons correctly. It will also focus on the restoration of functionality of the device and show the proper placement of the buttons to restore the device to its retail form.
Partes
No se especificaron partes.
    • First, lodge the tip of the plastic iFixit opening tool into the top corner of the device.
    • Apply pressure upward with the iFixit Opening Tool. This should release the two panels away from each other.
  1. Griffin iFM 4027 Right Side Panel (Screen Side Up) Replacement: paso 2, imagen 1 de 3 Griffin iFM 4027 Right Side Panel (Screen Side Up) Replacement: paso 2, imagen 2 de 3 Griffin iFM 4027 Right Side Panel (Screen Side Up) Replacement: paso 2, imagen 3 de 3
    • Use your fingers to separate the right side panel from the device.
    • Turn the panel over so that the outer edge is facing downward.
    • Use your fingers to dislodge the buttons, and then set them aside for later.
  2. Griffin iFM 4027 Right Side Panel (Screen Side Up) Replacement, Right Side Panel (Screen Side Up): paso 3, imagen 1 de 1
    • Ensure that the elevated grating is on the left side of the button, as seen in the first posted image.
    • Insert the button with the sound diagrams to the top section of the panel.
  3. Griffin iFM 4027 Right Side Panel (Screen Side Up) Replacement: paso 4, imagen 1 de 1
    • Ensure that the elevated grating is on the left side of the button, as seen in the posted image.
    • Insert the button with the two arrows to the bottom section of the panel.
  4. Griffin iFM 4027 Right Side Panel (Screen Side Up) Replacement: paso 5, imagen 1 de 1
    • Be careful with handling the panel during placement. Utilize gravity to keep the buttons from falling out.
    • Using your fingers, carefully click in the bottom end of the panel, followed by the top end of the panel.
  5. Griffin iFM 4027 Right Side Panel (Screen Side Up) Replacement: paso 6, imagen 1 de 2 Griffin iFM 4027 Right Side Panel (Screen Side Up) Replacement: paso 6, imagen 2 de 2
    • Apply pressure to both side panels simultaneously to ensure the device has restored original stability.
Conclusión
After installation, the device should look similar to that which is depicted in the cover image (top right of page).
Alexander
Miembro Desde 09/03/12
101 Reputación
9 Guías creadas
Equipo
Clemson, Team 15-3, Benson Spring 2012 Miembro de Clemson, Team 15-3, Benson Spring 2012
CLEM-BENSON-S12S15G3
3 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 901
