Saltar al contenido principal
Griffin iFM 4027 Left Side Panel Replacement
Qué necesitas
  1. Griffin iFM 4027 Left Side Panel Replacement, Left Side Panel: paso 1, imagen 1 de 1
    • Lodge the tip of the plastic opening tool into the top arc where the side and main part of the device meet.
    • Push the plastic opening tool upward until the side panel detaches.
  2. Griffin iFM 4027 Left Side Panel Replacement: paso 2, imagen 1 de 3 Griffin iFM 4027 Left Side Panel Replacement: paso 2, imagen 2 de 3 Griffin iFM 4027 Left Side Panel Replacement: paso 2, imagen 3 de 3
    • Slide the plastic opening tool along the panel seam and push upward until the side panel detaches from the main device.
    • Turn over the detached side panel, so that the outer side is facing downward.
    • Then use your fingers to disassemble the panel button and set it off to the side.
Conclusión
Alexander
Miembro Desde 03/09/12
101 Reputación
6 Guías creadas
Equipo
Clemson, Team 15-3, Benson Spring 2012 Miembro de Clemson, Team 15-3, Benson Spring 2012
CLEM-BENSON-S12S15G3
3 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 9
Ultimos 30 días: 13
Todo El Tiempo: 1,131
