Saltar al contenido principal
Introducción
This guide will teach the user how to install the left side panel and align the "mode" button correctly. It will also show the proper placement of the button to restore the device to its retail form.
Partes
No se especificaron partes.
  1. Griffin iFM 4027 Left Side Panel (Screen Side Up) Replacement, Disassembling Griffin iFM 4027 Left Side Panel (Screen Side Up): paso 1, imagen 1 de 1
    • Lodge the tip of the plastic opening tool into the top arc where the side and main part of the device meet.
    • Push the plastic opening tool upward until the side panel detaches.
  2. Griffin iFM 4027 Left Side Panel (Screen Side Up) Replacement: paso 2, imagen 1 de 3 Griffin iFM 4027 Left Side Panel (Screen Side Up) Replacement: paso 2, imagen 2 de 3 Griffin iFM 4027 Left Side Panel (Screen Side Up) Replacement: paso 2, imagen 3 de 3
    • Slide the plastic opening tool along the panel seam and push upward until the side panel detaches from the main device.
    • Turn over the detached side panel, so that the outer side is facing downward.
    • Then use your fingers to disassemble the panel button and set it off to the side.
  3. Griffin iFM 4027 Left Side Panel (Screen Side Up) Replacement, Left Side Panel (Screen Side Up): paso 3, imagen 1 de 2 Griffin iFM 4027 Left Side Panel (Screen Side Up) Replacement, Left Side Panel (Screen Side Up): paso 3, imagen 2 de 2
    • Ensure that the elevated grating is on the right side of the button in respect to the panel position seen in the first image.
    • Insert the button into the side panel's designated slot using your fingers or tweezers if necessary.
  4. Griffin iFM 4027 Left Side Panel (Screen Side Up) Replacement: paso 4, imagen 1 de 2 Griffin iFM 4027 Left Side Panel (Screen Side Up) Replacement: paso 4, imagen 2 de 2
    • Insert the top arc of the side panel into the top end of the device's side as seen in the second image.
  5. Griffin iFM 4027 Left Side Panel (Screen Side Up) Replacement: paso 5, imagen 1 de 2 Griffin iFM 4027 Left Side Panel (Screen Side Up) Replacement: paso 5, imagen 2 de 2
    • Push the bottom end of the panel into the panel slot and apply additional pressure to the side panel to ensure it is attached to the device securely.
Conclusión
After installation, the device should look similar to that which is depicted in the cover image (top right of page).
Alexander
Miembro Desde 09/03/12
101 Reputación
9 Guías creadas
Equipo
Clemson, Team 15-3, Benson Spring 2012 Miembro de Clemson, Team 15-3, Benson Spring 2012
CLEM-BENSON-S12S15G3
3 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 934
