Introducción
This guide will teach the user how to install the left side panel and align the "mode" button correctly. It will also show the proper placement of the button to restore the device to its retail form.
Partes
No se requieren partes.
  1. Lodge the tip of the plastic opening tool into the top arc of the front panel. Apply a little force to cause the panel to detach.
    • Lodge the tip of the plastic opening tool into the top arc of the front panel. Apply a little force to cause the panel to detach.
  2. Slide the blue opening tool along the seam applying force to continue detaching the side panel.
    • Slide the blue opening tool along the seam applying force to continue detaching the side panel.
    • Remove the button from the side panel.
    • Ensure that the elevated grating is on the right side of the button in respect to the panel position seen in the first image.
    • Insert the button into the side panel's designated slot using your fingers or tweezers if necessary.
    • Insert the top arc of the side panel into the top end of the device's side as seen in the second image.
    • Push the bottom end of the panel into the panel slot and apply additional pressure to the side panel to ensure it is attached to the device securely.
Conclusión
After installation, the device should look similar to that which is depicted in the cover image (top right of page).
Alexander
Miembro Desde 09/03/12
101 Reputación
9 Guías creadas
Equipo
Clemson, Team 15-3, Benson Spring 2012 Miembro de Clemson, Team 15-3, Benson Spring 2012
CLEM-BENSON-S12S15G3
3 Miembros
9 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 884
