Saltar al contenido principal
Introducción
This guide will teach you how to remove the circuit board from the device. This will allow a simple installation of an LCD screen cover.
Partes
No se especificaron partes.
  1. Lodge the tip of the plastic opening tool into the top arc of the front panel. Apply a little force to cause the panel to detach.
    • Lodge the tip of the plastic opening tool into the top arc of the front panel. Apply a little force to cause the panel to detach.
  2. Slide the blue opening tool along the seam applying force to continue detaching the side panel. Remove the button from the side panel. Remove the button from the side panel.
    • Slide the blue opening tool along the seam applying force to continue detaching the side panel.
    • Remove the button from the side panel.
  3. Use the plastic opening tool.
    • Use the plastic opening tool.
    • Lodge the tip into the corner of the device; Applying pressure upward, allowing the panel to be released.
  4. The side panel can now be detached using your fingers. The buttons can be dislodged by turning the panel over and shaking it, if necessary. The buttons can be dislodged by turning the panel over and shaking it, if necessary.
    • The side panel can now be detached using your fingers.
    • The buttons can be dislodged by turning the panel over and shaking it, if necessary.
  5. The central button can easily be removed by using your fingers or tweezers to push the button out towards the left panel. The central button can easily be removed by using your fingers or tweezers to push the button out towards the left panel.
    • The central button can easily be removed by using your fingers or tweezers to push the button out towards the left panel.
  6. Carefully remove the circuit board/LCD component from the device by pulling it towards the left open panel. Carefully remove the circuit board/LCD component from the device by pulling it towards the left open panel.
    • Carefully remove the circuit board/LCD component from the device by pulling it towards the left open panel.
  7. The screen cover can be easily lifted and removed from the LCD screen.
    • The screen cover can be easily lifted and removed from the LCD screen.
  8. Place the screen cover on top of the LCD so it covers its entirety. Carefully slide the circuit board/LCD back into the device. Place the screen cover on top of the LCD so it covers its entirety. Carefully slide the circuit board/LCD back into the device.
    • Place the screen cover on top of the LCD so it covers its entirety. Carefully slide the circuit board/LCD back into the device.
Conclusión
After installation, the device should look similar to that which is depicted in the cover image (top right of page).
Alexander
Miembro Desde 09/03/12
101 Reputación
9 Guías creadas
Equipo
Clemson, Team 15-3, Benson Spring 2012 Miembro de Clemson, Team 15-3, Benson Spring 2012
CLEM-BENSON-S12S15G3
3 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 958
