Introducción
Electric mowers differ from motor mowers that require pulling the starter fast and requires strength, which can cause frustration. Electric mowers are much more efficient to start. However, the lever can often break as they are hollow and fragile. While the replacement is easy, there are not many guides available. This guide will give you a step by step to replace a lever and the ability to resolve the issue of the lever not moving smoothly.
Qué necesitas
As seen in the picture, the lever is snapped on one side of the lever and needs replacement.
Insert the new lever starting with the left side while it is tilted downwards.
Tilt the lever up so that the lever on the left is fully inserted.
Squeeze the right side of the lever to Insert the right side of the lever.
Put the right side of the lever into the drill in the mowers handle.
Now that the lever is replaced be sure to be gentle with pull the lever back and placing the mower down. This will avoid future issues and another replacement.
Un comentario
I have a Greenwork 40 volt electric mower. I start it up correctly (first push down the start button, and as it is pushed down, then pull back on the starter lever. Suddenly, it shuts off now after 1 or 2 seconds. This occurs repeatedly and the mower is not operational. The two batteries are fully charged. Any suggestions?
