Introducción
If the white LED won't light up it may be an issue with the motor. You will need to take the Gravity Light apart and replace the motor.
Qué necesitas
Flip the GravityLight on its back and place it on a sturdy surface.
Unscrew the three 2cm Phillips #00 screws on the back of the GravityLight’s body.
Firmly grasp both parts of the GravityLight body and pull them apart.
Take the thicker of the two parts, the back piece, and place it face down on a sturdy surface.
Place the back panel, the larger of the two pieces, on a sturdy surface with its back down.
Unscrew the two 2cm Phillips 00 screws on the inside of the back panel.
Gently lift off the LED housing (the white disk).
Set the LED housing on the table next to the body of the device.
Lift off the white piece with four arms.
Lift off the black-rimmed gear.
Set both pieces aside in a safe place.
Remove the two 2cm Phillips 00 screws from the motor housing.
Firmly grasp both parts of the back panel and pull them apart.
Place the middle section flat with the side that holds the gear system down and locate the back of the motor.
Lift the motor out of the middle section. Using the flush wire cutters, clip the red and the blue wires located on the motor's back.
Una persona más ha completado esta guía.
