Introducción
If the white LED light will not turn on, then you will have to open up the device and replace the LED.
Qué necesitas
Flip the GravityLight on its back and place it on a sturdy surface.
Unscrew the three 2cm Phillips #00 screws on the back of the GravityLight’s body.
Firmly grasp both parts of the GravityLight body and pull them apart.
Place the back panel, the larger of the two pieces, on a sturdy surface with its back down.
Unscrew the two 2cm Phillips 00 screws on the inside of the back panel.
Grab the outside of the large, white gear in the LED housing and pull the gear out of the housing.
Set the LED housing flat on a sturdy surface so that the back of the LED and the wires are exposed.
Place the GravityLight's back panel aside.
Use the Flush Wire Cutter to cut both the purple wire and the red wire that connect to the LED.
Take tweezers and bend the leads (the silver wires coming out of the bulb) so that the leads are straight.
