Introducción
If the bag of rocks is not moving due to an internal issue, it might be because the gears are stripped! You will learn how to replace them.
Qué necesitas
Flip the GravityLight on its back and place it on a sturdy surface.
Unscrew the three 2cm Phillips #00 screws on the back of the GravityLight’s body.
Firmly grasp both parts of the GravityLight body and pull them apart.
Take the thicker of the two parts, the back piece, and place it face down on a sturdy surface.
Place the back panel, the larger of the two pieces, on a sturdy surface with its back down.
Unscrew the two 2cm Phillips 00 screws on the inside of the back panel.
Gently lift off the LED housing (the white disk).
Set the LED housing on the table next to the body of the device.
Lift off the white piece with four arms.
Lift off the black-rimmed gear.
Set both pieces aside in a safe place.
Lift off the three 3.5cm diameter gears.
Replace any stripped gears.
