Saltar al contenido principal
GravityLight Internal Gears Replacement
Qué necesitas
  1. GravityLight Internal Gears Replacement, Removing the Front Panel: paso 1, imagen 1 de 2 GravityLight Internal Gears Replacement, Removing the Front Panel: paso 1, imagen 2 de 2
    • Flip the GravityLight on its back and place it on a sturdy surface.
    • Unscrew the three 2cm Phillips #00 screws on the back of the GravityLight’s body.
  2. GravityLight Internal Gears Replacement, Opening the Device Housing: paso 2, imagen 1 de 1
    • Some of the internal pieces may loosen or fall out during disassembly.
    • Firmly grasp both parts of the GravityLight body and pull them apart.
  3. GravityLight Internal Gears Replacement, Isolating the Back Panel: paso 3, imagen 1 de 1
    • Take the thicker of the two parts, the back piece, and place it face down on a sturdy surface.
  4. GravityLight Internal Gears Replacement, Removing the Back Panel Screws: paso 4, imagen 1 de 1
    • Place the back panel, the larger of the two pieces, on a sturdy surface with its back down.
    • Unscrew the two 2cm Phillips 00 screws on the inside of the back panel.
  5. GravityLight Internal Gears Replacement, Removing the LED Housing: paso 5, imagen 1 de 1
    • Watch out for the wires! Keep them attached for this entire guide, or the GravityLight will not work!
    • Gently lift off the LED housing (the white disk).
    • Set the LED housing on the table next to the body of the device.
  6. GravityLight Internal Gears Replacement, Removing White Frame and Gear: paso 6, imagen 1 de 1
    • Lift off the white piece with four arms.
    • Lift off the black-rimmed gear.
    • Set both pieces aside in a safe place.
  7. GravityLight Internal Gears Replacement, Removing Internal Gears: paso 7, imagen 1 de 2 GravityLight Internal Gears Replacement, Removing Internal Gears: paso 7, imagen 2 de 2
    • Lift off the three 3.5cm diameter gears.
    • Replace any stripped gears.
Conclusión
Michallynn Hoffman
Miembro Desde 09/26/14
317 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 12-2, Forte Fall 2014 Miembro de Cal Poly, Team 12-2, Forte Fall 2014
CPSU-FORTE-F14S12G2
5 Miembros
7 Guías creadas
Un comentario
Where can we find the replacement gears?
fb - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 15
Todo El Tiempo: 3,071
