Saltar al contenido principal
GravityLight Dial Replacement
Qué necesitas
  1. GravityLight Dial Replacement, Removing the Front Panel: paso 1, imagen 1 de 2 GravityLight Dial Replacement, Removing the Front Panel: paso 1, imagen 2 de 2
    • Flip the GravityLight on its back and place it on a sturdy surface.
    • Unscrew the three 2cm Phillips #00 screws on the back of the GravityLight’s body.
  2. GravityLight Dial Replacement, Opening the Device Housing: paso 2, imagen 1 de 1
    • Some of the internal pieces may loosen or fall out during disassembly.
    • Firmly grasp both parts of the GravityLight body and pull them apart.
  3. GravityLight Dial Replacement, Isolating the Front Panel: paso 3, imagen 1 de 1
    • Take the thinner of the two parts, the front piece, and place it face down on a sturdy surface.
    • Ignore the back piece for now, but keep it in a safe place.
  4. GravityLight Dial Replacement, Popping the Dial out: paso 4, imagen 1 de 2 GravityLight Dial Replacement, Popping the Dial out: paso 4, imagen 2 de 2
    • Use two hands to push the dial tabs inward, towards the center of the dial.
    • Push the tabs downward and through to the other side of the casing.
    • Flip the front panel over.
  5. GravityLight Dial Replacement, Removing the Dial: paso 5, imagen 1 de 1
    • Fully remove the dial by pulling it out from the front.
Conclusión
Equipo
Cal Poly, Team 12-2, Forte Fall 2014 Miembro de Cal Poly, Team 12-2, Forte Fall 2014
CPSU-FORTE-F14S12G2
5 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 14
Todo El Tiempo: 751
