Saltar al contenido principal
Graco Secure Coverage Parent Unit Battery Replacement
Qué necesitas
  1. Graco Secure Coverage Parent Unit Battery Replacement, Parent Unit Battery: paso 1, imagen 1 de 3 Graco Secure Coverage Parent Unit Battery Replacement, Parent Unit Battery: paso 1, imagen 2 de 3 Graco Secure Coverage Parent Unit Battery Replacement, Parent Unit Battery: paso 1, imagen 3 de 3
    • Using plastic opening tool, pry and remove the battery lid.
  2. Graco Secure Coverage Parent Unit Battery Replacement: paso 2, imagen 1 de 1
    • Remove the battery by holding the device with one hand and pulling the battery out with other hand carefully.
    • Make sure that you disconnect the battery's wire before you remove the battery.
Conclusión
Rogelio Morales
Miembro Desde 08/31/15
201 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 6-5, Remmell Fall 2015 Miembro de USF Tampa, Team 6-5, Remmell Fall 2015
USFT-REMMELL-F15S6G5
4 Miembros
8 Guías creadas
Un comentario
Would anyone happen to know the type of battery needed for the replacement on this baby monitor?
Shaun Barnes (WheelchairShaun) - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 10
Todo El Tiempo: 707
