Saltar al contenido principal
Graco Secure Coverage LED Nursery Unit Replacement
Qué necesitas
  1. Graco Secure Coverage LED Nursery Unit Replacement, Nursery Unit Battery: paso 1, imagen 1 de 3 Graco Secure Coverage LED Nursery Unit Replacement, Nursery Unit Battery: paso 1, imagen 2 de 3 Graco Secure Coverage LED Nursery Unit Replacement, Nursery Unit Battery: paso 1, imagen 3 de 3
    • Remove the 9mm screw from the battery cover of the nursery unit using a Phillips #1 tip screwdriver.
  2. Graco Secure Coverage LED Nursery Unit Replacement: paso 2, imagen 1 de 2 Graco Secure Coverage LED Nursery Unit Replacement: paso 2, imagen 2 de 2
    • Using the plastic opening tool, pry and remove the battery cover carefully.
    • Remove the batteries using plastic opening tool.
    • Replace the batteries.
  3. Graco Secure Coverage LED Nursery Unit Replacement, LED Nursery Unit: paso 3, imagen 1 de 2 Graco Secure Coverage LED Nursery Unit Replacement, LED Nursery Unit: paso 3, imagen 2 de 2
    • Remove the two 9mm Phillips #1 screws from the rare case of the device.
    • Place the screws in a secure place.
  4. Graco Secure Coverage LED Nursery Unit Replacement: paso 4, imagen 1 de 1
    • Hold the bottom of the device with one hand and pull down to separate the front and rare cases.
    • While holding the device with one hand, use plastic opening tool to pry the edges of the front case away from the back case.
    • Apply constant force carefully to avoid breaking any other plastic parts from the device.
  5. Graco Secure Coverage LED Nursery Unit Replacement: paso 5, imagen 1 de 2 Graco Secure Coverage LED Nursery Unit Replacement: paso 5, imagen 2 de 2
    • Remove all three 7mm Phillips #1 screws from the mother board.
    • Place the screws in secure place.
  6. Graco Secure Coverage LED Nursery Unit Replacement: paso 6, imagen 1 de 3 Graco Secure Coverage LED Nursery Unit Replacement: paso 6, imagen 2 de 3 Graco Secure Coverage LED Nursery Unit Replacement: paso 6, imagen 3 de 3
    • Flip over the motherboard to look at the LED pins that are connected to it.
    • Solder off the LED pin from the motherboard.
    • There are many pins are connect to the motherboard, so make sure that you solder off the LED pin.
    • Replace the LED.
Conclusión
Bryson Wolff
Miembro Desde 08/31/15
237 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 6-5, Remmell Fall 2015 Miembro de USF Tampa, Team 6-5, Remmell Fall 2015
USFT-REMMELL-F15S6G5
4 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 7
Todo El Tiempo: 140
