Saltar al contenido principal
Graco Literider Classic Connect Handle Cover Replacement
Qué necesitas
  1. Graco Literider Classic Connect Handle Cover Replacement, Handle Cover: paso 1, imagen 1 de 1
    • Flip the stroller over so that the screws on the handle are facing upwards.
    • Locate the four 22 mm Phillips screws on the underside of the handle.
  2. Graco Literider Classic Connect Handle Cover Replacement: paso 2, imagen 1 de 1
    • Using a Phillips #1 screwdriver, remove the four 22 mm screws and set them aside.
  3. Graco Literider Classic Connect Handle Cover Replacement: paso 3, imagen 1 de 1
    • Push the switch in to allow the handle cover to come free.
  4. Graco Literider Classic Connect Handle Cover Replacement: paso 4, imagen 1 de 1
    • Remove the handle cover from the handle.
    • Avoid pushing the two rods fully into the slots on the handle, as they can be very difficult to remove.
Conclusión
2 personas más completaron esta guía.
Tyler Laird
Miembro Desde 09/29/15
540 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 11-4, Forte Fall 2015 Miembro de Cal Poly, Team 11-4, Forte Fall 2015
CPSU-FORTE-F15S11G4
5 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 7
Ultimos 30 días: 13
Todo El Tiempo: 1,076
