Saltar al contenido principal
Governor Adjustment
Qué necesitas
  1. Governor Adjustment, Governor Adjustment: paso 1, imagen 1 de 3 Governor Adjustment, Governor Adjustment: paso 1, imagen 2 de 3 Governor Adjustment, Governor Adjustment: paso 1, imagen 3 de 3
    • Before starting, make sure the engine isn't running and is not hot.
    • Using needle-nose pliers, carefully unhook the spring from the end opposite the air filter.
  2. Governor Adjustment: paso 2, imagen 1 de 1
    • Use the needle-nose pliers to either lengthen or shorten the hook at the end of the spring.
    • If your engine is stalling or refusing to start, try shortening the spring. This will enable more fuel to reach to engine at idle. If the engine is bogged down when running and you hear liquids splashing, try lengthening the spring.
  3. Governor Adjustment: paso 3, imagen 1 de 1
    • Carefully re-hook the spring on the arm it was disconnected from.
Conclusión
Aaron Correya
Miembro Desde 04/19/18
239 Reputación
2 Guías creadas
Equipo
Cal Poly, Team S25-G15, Maness Spring 2018 Miembro de Cal Poly, Team S25-G15, Maness Spring 2018
CPSU-MANESS-S18S25G15
4 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 11
Ultimos 30 días: 50
Todo El Tiempo: 2,475
