Saltar al contenido principal
Google Pixelbook Right Charging Port Replacement
Qué necesitas
  1. Google Pixelbook Right Charging Port Replacement, Battery (Back Panel): paso 1, imagen 1 de 3 Google Pixelbook Right Charging Port Replacement, Battery (Back Panel): paso 1, imagen 2 de 3 Google Pixelbook Right Charging Port Replacement, Battery (Back Panel): paso 1, imagen 3 de 3
    • Use the iFixit opening tools or a metal spudger to pry the rubber covers off the back of your Pixelbook.
    • Peel the linings off completely until the back of the Pixelbook looks bare.
  2. Google Pixelbook Right Charging Port Replacement: paso 2, imagen 1 de 2 Google Pixelbook Right Charging Port Replacement: paso 2, imagen 2 de 2
    • Remove the two yellow 2.0mm screws by using a T3 Torx screwdriver.
  3. Google Pixelbook Right Charging Port Replacement: paso 3, imagen 1 de 3 Google Pixelbook Right Charging Port Replacement: paso 3, imagen 2 de 3 Google Pixelbook Right Charging Port Replacement: paso 3, imagen 3 de 3
    • Remove the seventeen 3.0mm T5 Torx screws from the bottom panel.
  4. Google Pixelbook Right Charging Port Replacement: paso 4, imagen 1 de 3 Google Pixelbook Right Charging Port Replacement: paso 4, imagen 2 de 3 Google Pixelbook Right Charging Port Replacement: paso 4, imagen 3 de 3
    • Use the nylon spudger to pry the edge of the Pixelbook up until you can grab the edge with your fingers.
    • Open the back panel completely and lay it flat so you see the whole inside of the computer.
  5. Google Pixelbook Right Charging Port Replacement: paso 5, imagen 1 de 2 Google Pixelbook Right Charging Port Replacement: paso 5, imagen 2 de 2
    • Remove the yellow 2.0mm screw from the middle of the panel by using the T3 Torx screwdriver to turn the screw counterclockwise.
  6. Google Pixelbook Right Charging Port Replacement: paso 6, imagen 1 de 2 Google Pixelbook Right Charging Port Replacement: paso 6, imagen 2 de 2
    • Remove the small, black casing by using the spudger to lift it up from its place.
  7. Google Pixelbook Right Charging Port Replacement: paso 7, imagen 1 de 1
    • Disconnect the flat, black cord from the main component by using a spudger to push it out of the slot, or by using your hand to carefully pull it out.
    • Your back panel is now free from the main component.
  8. Google Pixelbook Right Charging Port Replacement, Right Charging Port: paso 8, imagen 1 de 2 Google Pixelbook Right Charging Port Replacement, Right Charging Port: paso 8, imagen 2 de 2
    • Remove the three 2.0mm black screws from the sound card by using a T5 Torx screwdriver to turn them counterclockwise.
    • Remove the gold 3.0mm screw by using a T3 Torx screwdriver to turn it counterclockwise.
  9. Google Pixelbook Right Charging Port Replacement: paso 9, imagen 1 de 1
    • Disconect the thin, black and red cord from the motherboard by using the spudger to snap the connector up and out of place.
  10. Google Pixelbook Right Charging Port Replacement: paso 10, imagen 1 de 1
    • Remove the yellow 2.0mm screw by using the T3 Torx screwdriver to turn the screw counterclockwise.
  11. Google Pixelbook Right Charging Port Replacement: paso 11, imagen 1 de 1
    • Remove the small, red component by lifting it up with the spudger.
  12. Google Pixelbook Right Charging Port Replacement: paso 12, imagen 1 de 1
    • Disconnect the metal component of the thin, black component by lifting it up with the spudger.
  13. Google Pixelbook Right Charging Port Replacement: paso 13, imagen 1 de 2 Google Pixelbook Right Charging Port Replacement: paso 13, imagen 2 de 2
    • Remove the right charging port by picking it up with the tweezers and lifting it from the computer.
Conclusión
Alon Gary
Miembro Desde 01/24/18
526 Reputación
2 Guías creadas
Equipo
Cal Poly, Team S18-G1, Livingston Winter 2018 Miembro de Cal Poly, Team S18-G1, Livingston Winter 2018
CPSU-LIVINGSTON-W18S18G1
4 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 1,579
