Introducción
In this guide, you will learn how to replace the right charging port on your Google Pixelbook to fix charging issues.
Qué necesitas
Use the iFixit opening tools or a metal spudger to pry the rubber covers off the back of your Pixelbook.
Peel the linings off completely until the back of the Pixelbook looks bare.
Remove the three 2.0mm black screws from the sound card by using a T5 Torx screwdriver to turn them counterclockwise.
Remove the gold 3.0mm screw by using a T3 Torx screwdriver to turn it counterclockwise.
