Saltar al contenido principal
Google Pixelbook Left Charging Port Replacement
Qué necesitas
  1. Google Pixelbook Left Charging Port Replacement, Battery (Back Panel): paso 1, imagen 1 de 3 Google Pixelbook Left Charging Port Replacement, Battery (Back Panel): paso 1, imagen 2 de 3 Google Pixelbook Left Charging Port Replacement, Battery (Back Panel): paso 1, imagen 3 de 3
    • Use the iFixit opening tools or a metal spudger to pry the rubber covers off the back of your Pixelbook.
    • Peel the linings off completely until the back of the Pixelbook looks bare.
  2. Google Pixelbook Left Charging Port Replacement: paso 2, imagen 1 de 2 Google Pixelbook Left Charging Port Replacement: paso 2, imagen 2 de 2
    • Remove the two yellow 2.0mm screws by using a T3 Torx screwdriver.
  3. Google Pixelbook Left Charging Port Replacement: paso 3, imagen 1 de 3 Google Pixelbook Left Charging Port Replacement: paso 3, imagen 2 de 3 Google Pixelbook Left Charging Port Replacement: paso 3, imagen 3 de 3
    • Remove the seventeen 3.0mm T5 Torx screws from the bottom panel.
  4. Google Pixelbook Left Charging Port Replacement: paso 4, imagen 1 de 3 Google Pixelbook Left Charging Port Replacement: paso 4, imagen 2 de 3 Google Pixelbook Left Charging Port Replacement: paso 4, imagen 3 de 3
    • Use the nylon spudger to pry the edge of the Pixelbook up until you can grab the edge with your fingers.
    • Open the back panel completely and lay it flat so you see the whole inside of the computer.
  5. Google Pixelbook Left Charging Port Replacement: paso 5, imagen 1 de 2 Google Pixelbook Left Charging Port Replacement: paso 5, imagen 2 de 2
    • Remove the yellow 2.0mm screw from the middle of the panel by using the T3 Torx screwdriver to turn the screw counterclockwise.
  6. Google Pixelbook Left Charging Port Replacement: paso 6, imagen 1 de 2 Google Pixelbook Left Charging Port Replacement: paso 6, imagen 2 de 2
    • Remove the small, black casing by using the spudger to lift it up from its place.
  7. Google Pixelbook Left Charging Port Replacement: paso 7, imagen 1 de 1
    • Disconnect the flat, black cord from the main component by using a spudger to push it out of the slot, or by using your hand to carefully pull it out.
    • Your back panel is now free from the main component.
  8. Google Pixelbook Left Charging Port Replacement, Left Charging Port: paso 8, imagen 1 de 2 Google Pixelbook Left Charging Port Replacement, Left Charging Port: paso 8, imagen 2 de 2
    • Remove the two 3.0mm silver screws from the thin, black component by using a T3 Torx screwdriver to turn the screws counterclockwise.
  9. Google Pixelbook Left Charging Port Replacement: paso 9, imagen 1 de 2 Google Pixelbook Left Charging Port Replacement: paso 9, imagen 2 de 2
    • Disconnect the thin, black and white cord from the motherboard by using the spudger to snap the connector up and out of place.
  10. Google Pixelbook Left Charging Port Replacement: paso 10, imagen 1 de 1
    • Remove the thin, black component by pulling it up and out of the laptop with your fingers.
    • This photo shows the bottom screw still in the black box, but yours should be removed.
  11. Google Pixelbook Left Charging Port Replacement: paso 11, imagen 1 de 1
    • Remove the gold 2.0mm corner screw by turning it counterclockwise with a T3 Torx screwdriver.
  12. Google Pixelbook Left Charging Port Replacement: paso 12, imagen 1 de 2 Google Pixelbook Left Charging Port Replacement: paso 12, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Using needle-nose tweezers, remove the silver casing by lifting it up and out of the computer.
  13. Google Pixelbook Left Charging Port Replacement: paso 13, imagen 1 de 2 Google Pixelbook Left Charging Port Replacement: paso 13, imagen 2 de 2
    • Remove the three 3.0mm black screws on the right side by using a T5 Torx screwdriver to turn the screws counterclockwise.
    • Remove the silver 2.0mm screw on the left side by using a T3 Torx screwdriver to turn the screw counterclockwise.
  14. Google Pixelbook Left Charging Port Replacement: paso 14, imagen 1 de 1
    • Disconnect the thin, black ribbon cable by using the spudger to lift it up from the computer.
  15. Google Pixelbook Left Charging Port Replacement: paso 15, imagen 1 de 2 Google Pixelbook Left Charging Port Replacement: paso 15, imagen 2 de 2
    • Use the needle-nose tweezers to remove the charging port by lifting the component up and out of the Pixelbook.
Conclusión
Una persona más ha completado esta guía.
Alon Gary
Miembro Desde 01/24/18
556 Reputación
2 Guías creadas
Equipo
Cal Poly, Team S18-G1, Livingston Winter 2018 Miembro de Cal Poly, Team S18-G1, Livingston Winter 2018
CPSU-LIVINGSTON-W18S18G1
4 Miembros
8 Guías creadas
3 comentarios
Where to get replacemt charging port from please
kamil Szym - Contestar
Where can we get a replacement charging port for the Pixelbook Go 2 (i7)?
michaelnic - Contestar
Hi Michael, did you manage to find the charging port and replace it for the Pixelbook Go?
redshift galaxy -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 28
Todo El Tiempo: 2,957
