Qué necesitas
Use a metal spudger to gently lift up one corner of the rubber strips on the base. The strips are actually composed partially of hard plastic and will not stretch or deform, and should easily pop off with only gentle tugging.
Quite easy to pop off in to time at all, and easy to reassemble - just make sure you put screws back in the right places!
12 personas más completaron esta guía.
3 comentarios
I have a problem with the Pixelbook Go hinge. The pin popped out on one side. How do I disassemble/assemble the clamshell so I can pop the pin back into the hinge? See Re-insert clamshell pin into hinge
My camera and touchscreen stopped working. I believe a cable must be disconnected inside. Can I access from the bottom or do I need to disassemble the screen? Any ideas on how to fix it?
