Saltar al contenido principal
Google Pixel Slate Speaker Replacement
Qué necesitas
  1. Google Pixel Slate Speaker Replacement, Screen: paso 1, imagen 1 de 3 Google Pixel Slate Speaker Replacement, Screen: paso 1, imagen 2 de 3 Google Pixel Slate Speaker Replacement, Screen: paso 1, imagen 3 de 3
    • Orient the Google Pixel Slate so that the screen is facing upwards.
    • Use the iFixit opening tool to separate screen from main body.
    • Use the suction cup to remove the screen from the body of the device.
  2. Google Pixel Slate Speaker Replacement: paso 2, imagen 1 de 3 Google Pixel Slate Speaker Replacement: paso 2, imagen 2 de 3 Google Pixel Slate Speaker Replacement: paso 2, imagen 3 de 3
    • Gently disconnect the three flat-wires from the screen.
    • Carefully separate and remove the screen from the body of the device.
  3. Google Pixel Slate Speaker Replacement, Speaker: paso 3, imagen 1 de 3 Google Pixel Slate Speaker Replacement, Speaker: paso 3, imagen 2 de 3 Google Pixel Slate Speaker Replacement, Speaker: paso 3, imagen 3 de 3
    • There are two speakers, one on each side of the Google Pixel Slate. This guide works for either one.
    • Use the T2 Torx screwdriver to remove the yellow 2mm screw from the thin metal plate.
    • Use the T3 Torx screwdriver to remove the pink 3mm screw from the thin metal plate.
    • Remove the thin metal plate from the device.
  4. Google Pixel Slate Speaker Replacement: paso 4, imagen 1 de 1
    • Use the T2 Torx screwdriver to remove the two black 2mm screws from the speaker.
  5. Google Pixel Slate Speaker Replacement: paso 5, imagen 1 de 2 Google Pixel Slate Speaker Replacement: paso 5, imagen 2 de 2
    • Use the Nylon-Tipped Tweezers to remove the black plug.
    • There is a red and a black wire connected to the black plug.
    • Pull the black plug in an upwards direction.
    • Be sure to gently remove plug, as using too much force can damage the connecting wires.
  6. Google Pixel Slate Speaker Replacement: paso 6, imagen 1 de 2 Google Pixel Slate Speaker Replacement: paso 6, imagen 2 de 2
    • Use the Nylon-Tipped Tweezers to disconnect the black tape-like plug connected to the speaker.
  7. Google Pixel Slate Speaker Replacement: paso 7, imagen 1 de 2 Google Pixel Slate Speaker Replacement: paso 7, imagen 2 de 2
    • Detach the speaker wire from the motherboard.
    • Remove the adhesive strips that hold down the speaker wire.
  8. Google Pixel Slate Speaker Replacement: paso 8, imagen 1 de 3 Google Pixel Slate Speaker Replacement: paso 8, imagen 2 de 3 Google Pixel Slate Speaker Replacement: paso 8, imagen 3 de 3
    • Use the T2 Torx screwdriver to remove the 2mm black screw from the brass plate.
    • Pull back the brass plate.
  9. Google Pixel Slate Speaker Replacement: paso 9, imagen 1 de 1
    • You can now remove the speaker from the device.
Conclusión
3 personas más completaron esta guía.
Spencer Alonge
Miembro Desde 04/18/19
648 Reputación
5 Guías creadas
Equipo
Cal Poly, Team S2-G5, Maness Spring 2019 Miembro de Cal Poly, Team S2-G5, Maness Spring 2019
CPSU-MANESS-S19S2G5
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 8
Todo El Tiempo: 873
