Saltar al contenido principal
Google Pixel Slate Screen Replacement
Qué necesitas
  1. Google Pixel Slate Screen Replacement, Screen: paso 1, imagen 1 de 3 Google Pixel Slate Screen Replacement, Screen: paso 1, imagen 2 de 3 Google Pixel Slate Screen Replacement, Screen: paso 1, imagen 3 de 3
    • Orient the Google Pixel Slate so that the screen is facing upwards.
    • Use the iFixit opening tool to separate screen from main body.
    • Use the suction cup to remove the screen from the body of the device.
  2. Google Pixel Slate Screen Replacement: paso 2, imagen 1 de 3 Google Pixel Slate Screen Replacement: paso 2, imagen 2 de 3 Google Pixel Slate Screen Replacement: paso 2, imagen 3 de 3
    • Gently disconnect the three flat-wires from the screen.
    • Carefully separate and remove the screen from the body of the device.
Conclusión
4 personas más completaron esta guía.
Spencer Alonge
Miembro Desde 04/18/19
648 Reputación
5 Guías creadas
Equipo
Cal Poly, Team S2-G5, Maness Spring 2019 Miembro de Cal Poly, Team S2-G5, Maness Spring 2019
CPSU-MANESS-S19S2G5
4 Miembros
5 Guías creadas
11 comentarios
Where did you source the replacement screen? Can we get a link added to the parts list?
Brandon Price - Contestar
Anyone know where to source the replacement screen? Any help would be greatly appreciated.
Yeah, I could use the replacement source as well. Thanks.
Benjamin Reese - Contestar
me too! the resource replacement link plz!!
gabriela urquidi - Contestar
Is the screen held down with adhesive or does it have any clips? Also, does anyone know where I could source any Pixel Slate parts?
Kevin Freyre - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 15
Ultimos 30 días: 62
Todo El Tiempo: 4,519
